Activity Forums Maxon Cinema 4D External compositing problem in C4D
  • External compositing problem in C4D
    Posted by Vipati Hitesh on October 30, 2012 at 6:05 pm
    Hello All,
    I have basic knowledge of C4D R11.5 and After Effects cs5.5 and I
    am learning it myself form internet tutorials.Now,I am trying to
    import C4D projects in AE.
    In this process I have one problem. I am not able to import
    External compositing solid in AE correctly. Let me saw you
    snapshots so that you can understand my exact problem.
    1. I created a plane of 400*400
    2. I gave external compositing tag to this plane and made 350*350
    red solid.
    3. I import this project to AE and below result is coming
    But I don’t want this result because direction of red solid is not
    matching with plane.
    Why this is happning??? What I am doing wrong?? I want that red
    solid 350*350 in the direction of plane 400*400.
    Can I see the posotion and direction of the red solid before
    rendering???
    Thanks in advance..
    Regards,
    Vipati
    Vipati Hitesh replied 13 years, 10 months ago 2 Members · 2 Replies
  • Darby Edelen
    October 30, 2012 at 6:19 pm
    This has to do with the way AE treats the coordinate axis of a solid layer. The face of the solid is always pointing down the Z axis, which is the blue axis in C4D. You’ll need to make sure that your plane has its blue Z axis pointing in the direction you want your AE solid facing.
    If the plane is still a primitive you can do this by setting its orientation to either +Z or -Z and then rotating the plane back into the correct orientation.
    If it’s not a primitive then you’ll need to use the axis tool to rotate the Z axis into the correct orientation.
    Darby Edelen
  • Vipati Hitesh
    October 31, 2012 at 4:35 am
    HelloDarby Edelen,
    Thank you for your quick reply. I got the point.
