Activity Forums Blackmagic Design extension cables for the decklink?
  • extension cables for the decklink?
    Posted by Jeremiah Black on June 28, 2005 at 4:44 pm
    The digibeta deck in my new office is about 15 feet away from the reach of my decklink extreme card. Can anyone recommend a brand and seller of extention cables? I guess at a minimum, I would need an SDI extension and an RS422 extension. BUt what about genlock and the other cables? Just BNC or something special?
    thanks to anyone who can help,
    – jeremiah black
    Jeremiah Black replied 21 years, 2 months ago 3 Members · 3 Replies
  • Sean Oneil
    June 29, 2005 at 6:15 am
    It’s nothing special. Get female to female adapters and use regular 75ohm BNC cables. As for RS422, any 9-pin adapter or extension cable from any PC store will do.
  • Luke Maslen
    June 30, 2005 at 7:36 am
    Hi Jeremiah,
    Sean’s advice is spot on. However make sure you are using good quality SDI cables. You’re working in SD-SDI and so don’t need the more expensive HD-SDI cables. However if you work with a mix of SD and HD gear, then having different grades of cables can be confusing and it is better to standardize on HD-rated cables. We have a technical note about cables for HD-SDI at https://www.blackmagic-design.com/support/detail.asp?techID=90.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Jeremiah Black
    July 2, 2005 at 3:47 am
    Thanks guys. I found the cables and everything looks great. Much appreciated.
    I will say that finding a male to female RS-422 cable proved to be a huge pain. You have to buy a male to male and then buy a gender changer. Odd. But works.
    thanks again,
    – jeremiah black, NYC
