Activity Forums Adobe After Effects Expressions ExtendScript: ListBox multicolumn titles not working?
  • ExtendScript: ListBox multicolumn titles not working?
    Posted by Thor Sarup on August 17, 2013 at 6:20 pm
    This works in AE CS6:
    var layerList = myPanel.add("listbox", [0, 0, 150, 180], [""], {multiselect:false, numberOfColumns:3, showHeaders:true, closeButton:true, columnTitles: ['#', 'Layer Name', 'Duration' ], columnWidths: [20,80,40]});
    But in AE CS5 it doesn’t though it seems like it should according to ESTK help file. Any suggestions?
    columnTitles simply isn’t a property of listbox in AE CS5 (?)
    Thor Sarup replied 13 years ago 2 Members · 2 Replies
  • Xavier Gomez
    August 17, 2013 at 6:59 pm
    Hi, i tried your code and it didnt work in CS5.5. I don’t know what the 3rd argument [“”] is supposed to be.
    However it does work with a ressource string:
    var layerList = myPanel.add("listbox{bounds: [0, 0, 150, 180], properties:{multiselect:false, numberOfColumns:3, showHeaders:true, closeButton:true, columnTitles: ['#', 'Layer Name', 'Duration' ], columnWidths: [20,80,40]}});
    Xavier
  • Thor Sarup
    August 17, 2013 at 9:39 pm
    awesome. It works in AE CS5 too.
    Resourcestring is the way to go then 🙂
    Thanks for the help!
