Activity › Forums › VEGAS Pro › Extending endpoint on graphic gets aliased
  • Extending endpoint on graphic gets aliased
    Posted by Kelly Griffin on April 26, 2024 at 5:48 pm
    I don’t know if this has always been happening, but: I have an animated name identifier that’s one second long plus a one-second hold. In my project, I need it to hold another two seconds, but as soon as the player head reaches the actual end of the clip (and into the extended hold part) the graphic turns aliased (jagged edges). It’s slight, but definitely noticeable.
    I already know a workaround, but I’m just wondering it this is a bug or if there’s a setting I should have turned on that I don’t (?)
    Thanks fellas!
    –Kelly
    Hector Vera replied 2 years, 5 months ago 2 Members · 1 Reply
  • Hector Vera
    April 29, 2024 at 3:15 pm
    This could be a bug indeed, sometimes I would get corrupted video clips that gets glitched out and normally I would cut those parts out but if its doing it the whole clip, then it could be something wrong with the SD card that was recording that clip. If you are able to show me some screenshots on how its visually looking on your end or a video clip demostrating it. Perhaps I can help you further on that! Hope to hear from you soon!
