Extending an edit in the MIDDLE of a sequence
I’ll do my best to describe my problem.
I’m in the middle of a sequence and have slid a clip such that it has now cut off the end of the action (I needed to have more at the beginning). I could slip or slide the next clip, and the next, etc. though the whole sequence, but that seems absurd. I actually want to change the length of the clip I’m working on. Effectively I want to extend the clip by 30 frames, pushing the next clip by the same number, rather than cutting into either one.
I could remove that clip, then re-insert it with a corrected length, but this seems like something that there would be a command or function for. None of the commands I’m aware of will do this. What am I missing?
Thank you,
NelsonRed Camera Production, Denver Colorado. 303.506.2456
https://www.rockymountain4k.com
