Activity › Forums › Adobe Premiere Pro › Extend left and right side of transition together?
  • Extend left and right side of transition together?
    Posted by Diana Gualda on November 13, 2014 at 10:43 pm
    Hi, this has to be a very basic thing, but I can’t figure it out. Is there a way to extend or shorten both the left and right ends of a transition simultaneously? It seems an awful waste of time to have to drag each end individually when I just need the overall length of it to evenly extend. I used to do this in FCP all the time.
    Paul Neumann replied 11 years, 10 months ago 3 Members · 4 Replies
  • Jerry Wise
    November 13, 2014 at 11:22 pm
    ditto..plus how about “Transition Alignment” Start on Edit/Center on Edit/End on Edit.
  • Paul Neumann
    November 14, 2014 at 1:54 am
    In 2014.1 if you drag on one side it extends both sides. If you’re not getting this just double click on the transition and it will open up duration dialogue box. As far as aligning it you can just drag the transition however you want over the cut. No more “Start/End/Center on Cut”.
  • Diana Gualda
    November 14, 2014 at 2:18 am
    Paul, what do you mean “2014?” CS6? I’m in CS6 and dragging one side only extends the one side. Can double click, but clicking and typing an amount still seems like just as much fuss as dragging both ends individually.
  • Paul Neumann
    November 14, 2014 at 3:09 am
    CC 2014.1
    Big improvements since CS6.
