Activity › Forums › Adobe After Effects › Extend Edges of Mask
  • Tudor “ted” jelescu
    May 14, 2011 at 10:40 pm
    I am not sure if I understand your issue correctly, but if you are referring to a mask on a layer you have the option to Expand and Feather the edge. If it’s an alpha channel then a Matte Choker may do the trick.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Harry Evans
    May 15, 2011 at 11:46 am
    Yes, Mask Expansion is the one. That’s great. BUT, I also want the expansion to fade away. As in I want the expansion part to fade away towards the OUTER edge.
    May 15, 2011 at 4:09 pm
    Feather the mask and you should get that. You will probably need to adjust the expansion and the feathering together to get the result you want.
    Tudor “Ted” Jelescu
    Senior VFX Artist
