Activity › Forums › Adobe After Effects › Exruding 2d objects in the 3d space…
Posted by Graber on January 29, 2007 at 9:56 pmI have created a 2.5D world, with 2d objects flying around in a 3d space… I was wondering if there was a plugin that i could add that would extrude the 2d objects into 3d objects so i dont have to reanimate in a 3d program.
Jimmy Brunger replied 19 years, 8 months ago 3 Members · 2 Replies -
Mike Clasby
January 29, 2007 at 11:05 pmHere is a plugin, 3D Layer:
https://www.digitalanarchy.com/3Dlayer/3Dlayer_main.html
Here’s an earlier post for adding Z-depth with multiple layers via an expression, see 2):
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=891542
Also this is true AE 3D so you can fly the camera, also if you want to try a different offset for the spacing between layers, highlight the “1” at the end of the expression and pickwhip it to a Slider, then dup the layers, then it’s very adjustable. This same methods is used in this tut only without the expression, he offsets the layers manually 3 pixels:
https://www.creativecow.net/articles/woodall_traylor/3dtypetut2/index.html
Here’s a tut by Roland using Shatter:
https://www.creativecow.net/articles/kahlenberg_roland/3d_logo_extrude/index.html
Here’s an earlier post with ball action, just do it without the twist:
https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=895873
Jimmy Brunger
January 30, 2007 at 2:36 pmHaven’t d/loaded all the relevant demos yet…but in the opinion of anyone who’s used both; are you better off getting Zaxwerks Pro Animator to work with AE, or the Digital Anarchy 3D pack?
I mean, I know one is a 3D app (of sorts) and the other is a plugin for what is essentially a 2D app (AE) but which works the most seamlessly with AE?
Any thoughts appreciated.
Thanks.*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
