Activity Forums Adobe After Effects Expressions Expressions to sort numbers in descending order.
  • Expressions to sort numbers in descending order.
    Posted by Obed Ampong on September 11, 2020 at 5:43 pm
    Hello,
    Please, I found this expression in the old feed but it is not working for AE 2020. I am actually trying to create something like a league table and would like to link the values to the source text to arrange them in descending order.
    a = [12,5,9,10,3];
    a.sort(function(a, b){return a – b});
    a.toSource();
    Could there be a way out?
    Thanks in advance
    Obed
    Obed Ampong replied 6 years ago 4 Members · 6 Replies
  • Brendon Murphy
    September 11, 2020 at 7:38 pm
    See if this does it:
    values = [12,5,9,10,3];
    sorted = values.sort(function(a, b){return b-a});
    sorted;
  • Obed Ampong
    September 22, 2020 at 1:31 am
    Thanks, it worked, but please one more thing I want it to displace on the y-axis like without commas but space intervals. Is there a way out?
    12
    10
    9
    3
  • Filip Vandueren
    September 22, 2020 at 7:51 am
    Last line should be:
    sorted.join(“\r”);
    Which joins the elements of the array into a string with return-characters inbetween every element.
  • Andrei Popa
    September 22, 2020 at 7:57 am
    I think he needs and extra “\r” for the empty lines
    sorted.join(“\r\r”)
  • Filip Vandueren
    September 22, 2020 at 8:04 am
    I’d do that with leading 🙂
  • Obed Ampong
    September 22, 2020 at 2:10 pm
    Thank you very much
