Activity Forums Adobe After Effects Expressions Expressions to make a drop shadow interact with 2D background.
  • Expressions to make a drop shadow interact with 2D background.
    Posted by Robert Combs on February 5, 2007 at 6:45 pm
    Hi everyone,
    Can someone help me with this…?
    Is there a way (using expressions) to set up a drop shadow effect so that when the object moves away from the background, the drop shadow becomes more blurry and offset?
    Unfortunately, because of other factors, I can’t do this element in 3D or I would simply do it this way.
    Thanks, Rob
    Dan Ebberts
    replied 19 years, 7 months ago
    2 Members · 1 Reply
  • Dan Ebberts
    February 5, 2007 at 10:32 pm
    If it’s not 3D, how does the object “move away” from the background. By scaling?
    If so, some variation of these expressions for Distance and Softness should work:
    // Distance
    minScale = 50;
    maxScale = 200;
    minDistance = 5;
    maxDistance = 20;
    linear (scale[0],minScale,maxScale,minDistance,maxDistance)
    // Softness
    minScale = 50;
    maxScale = 200;
    minSoftness = 0;
    maxSoftness = 40;
    linear (scale[0],minScale,maxScale,minSoftness,maxSoftness)
    Set the values of the parameters to fit your needs.
    Dan
