Activity › Forums › Adobe After Effects Expressions › Expressions to edit and access text properties
  • Andrei Popa
    July 3, 2021 at 3:02 pm
    Unfortunately you can only change the style for the entire layer right now. I hope that in a future version Adobe would at least make it possible to change the font via text animators. Until then, all you can do is change the size/tracking/stroke of the font to mimic a bigger/bolder font. If the fonts you want to use are different typefaces entirely, I’m afraid there is no solution.
