Activity Forums Adobe After Effects Expressions Expressions + Text Animators
  • Expressions + Text Animators
    Posted by Emmanuel Gobert on April 24, 2012 at 9:39 pm
    Hi everyone,
    I’m quite new to text animators, but I was able to achieve this short animation, which is a base to a animation I want to create : https://youtu.be/vmLvLgKLdtQ
    For this animation I have animated “opacity” property
    As you can see it is very simple but I want to enhance this animation in the following way:
    as you can see in this animation, the opacity of each letters increase from 0% to 100% in a linear and constant way.
    What I want to do is to increase opacity of each letters from 0 to 100 % but with a kind of wiggle, in fact in the way a neon light is appearing…
    My problem is : I don’t know what expression to use to do that, plus I don’t know where to put this expression in text animators properties…. I’m sure it’s pretty simple, so I hope someone has a answer…
    Thanks in advance, and pardon my english !
    Emmanuel.
    Emmanuel Gobert replied 14 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
