Expressions linking outpoint to inpoint
Hi There,
After a couple of years spongeing off everyone else’s problems and answers, I have one of my own – hope someone can help.
I have a complex comp that feeds off other comps, but my problem is quite clear and straghtforward. I have 2 layers (pre-comps), and I need to link the inpoint of layer 2 to the outpoint of layer 1, preferably with the option to overlap by a few frames. I figure there must be a way to do this with expressions, but I’m not sure how to directly access the inpoint and outpoint layer properties.
I need to set it up this way because I have a complex comp that has featue sections which change in length, depending on the day. So if I change layer 1 from 10 seconds to 7, I want it to pull the inpoint (and out_point) of the next layer back with it.
Hope that makes sense – help very much appreciated.
Mike
