Activity › Forums › Adobe After Effects › expressions for unfolding layers in 3d space
  • expressions for unfolding layers in 3d space
    Posted by Karolina on August 17, 2005 at 5:02 pm
    i need to build a sequence of unfolding squares to create a “house of cards” effect, where new squares unfold out of the older ones in 3d so they create cubes. ideally i should be able to control the direction the layers are unfolding (since it shouldn’t be uniform in all directions).
    i tried working with trapcode’s particular, but it needs to be more structured in 3d, so i moved on to expressions and got stuck. any suggestions?
    karolina
    Mylenium replied 21 years, 1 month ago 2 Members · 1 Reply
  • Mylenium
    August 18, 2005 at 5:32 am
    Ahem, classical keyframe animation? Shouldn’t be to difficult, since all you need to worry about is properly setting your anchor points. Using expressions seems way off for this kind of project – it takes longer to adjust the formulas before you can get to work. Anyway, you’d have to be more specific about what you are trying to do. Expressions is such a large field.
    Mylenium
    [Pour Myl
