Activity › Forums › Adobe After Effects › expressions: Convert slider range into 0-360 degrees ?
  • expressions: Convert slider range into 0-360 degrees ?
    Posted by Andy Stokes on May 19, 2005 at 2:23 am
    Hi all,
    Can anyone tell me the string to convert from say 1-10 of a slider value into degrees of rotation (i.e : 0 – 360). 1 being one full rotation, 2 being 2 rotations etc…
    Thx,
    Andy
    Mike Clasby replied 21 years, 4 months ago 4 Members · 5 Replies
  • Colin Braley
    May 19, 2005 at 2:32 am
    I’m not sure if i’m understanding you’r question…So you are trying to convert the slider’s values so that 1 on the slider is 360 degrees? If so you should just pick whip the rotation value to the slider and then add * 360 on the end.
    ~Colin
  • Andy Stokes
    May 19, 2005 at 2:38 am
    Hi Colin,
    THanks for pointing out the obvious…. Sometimes I make things more complicated than they need be..
    Cheers,
    Andy
  • Steve Roberts
    May 19, 2005 at 2:44 am
    I guess you can’t use the “angle” expression control?
    Steve
  • Mike Clasby
    May 19, 2005 at 3:10 am
    Can’t you just right click the slider numbers (then select > edit Value, from the drop down)in the Effect Control Window (F3) and change the slider range to 0-360? Is that what you want?
  • Mike Clasby
    May 19, 2005 at 5:05 am
    My mistake. I’m with Steve Roberts, check out the “Angle Control” instead of slider.
