Activity Forums Adobe After Effects Expressions Expressions and contents problem
  • Expressions and contents problem
    Posted by Diego Mellado on June 4, 2014 at 3:32 pm
    Hello!
    First of all, thanks for your attention. I am having trouble with the following expressions.
    Whilie this works OK:
    comp("Mask").layer(thisLayer.name).content(5).content("Shape 1").content("Path 1").path
    This one doesn’t:
    index = 5;
    comp("Mask").layer(thisLayer.name).content(index).content("Shape 1").content("Path 1").path
    Does anyone have an idea on why?
    I am using CS6 on Mavericks.
    Thanks a lot!
    Diego
    Diego Mellado replied 12 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 4, 2014 at 3:53 pm
    One thing I see is that “index” is a reserved word representing the layer’s order in the layer stack. So setting index = 5 won’t do anything and when you refer to index in the next line, what you’ll get is the index of the layer hosting the expression. Try something like idx instead.
    Dan
  • Diego Mellado
    June 4, 2014 at 5:27 pm
    So obvious I feel stupid…
    Thanks a lot!
    D!
