Activity Forums Adobe After Effects Expressions: Access text of a pre-comp from outside
  • Expressions: Access text of a pre-comp from outside
    Posted by Dennis Dillert on May 27, 2009 at 6:06 pm
    Hi again,
    is there a way to change the contents of a text field using expressions? And if there is, how can you access a text field from outside of a pre-comp layer?
    Basically, I have one pre-comp with several text fields inside and I want to re-use this template for other things, but I’m too lazy to manually adjust all the individual text fields everytime.
    Dennis
    Dennis Dillert replied 17 years, 4 months ago 59,538 Members · 1 Reply
