  • Posted by Iryna Tietje on September 22, 2009 at 4:04 pm
    Please, need help. I want to make 5 pictures to move around in a perfect circle, so that they always face the camera. the pictures should move around the circle. but they should not rotate around there own axes. they should remain always 90 degrees. does anybody have the idee, what kind of expression i need. thnks a lot.
    Curious Turtle replied 17 years ago 2 Members · 1 Reply
  • Curious Turtle
    September 23, 2009 at 7:32 am
    The easiest way to do this would be to use parenting rather than expressions.
    i) Create a null layer and add a camera too.
    ii) Add your five picture layers and turn all six layers into 3D layers.
    iii) Set the z-position of your picture layers to a suitable distance.
    iv) Parent the first picture layer to the null object.
    v) Rotate the null object 72 degrees in Y. Parent the next picture, rotate the null 72 degrees in Y. Repeat for all the others.
    vi) If your layers aren’t all facing forwards, then select the pictures, right-click > Transform > Auto-orient and orient towards the camera.
    Should be job done there. You can adjust the z distance if your pictures are still crashing into each other.
    Hope that helps,
    Ben
    Curious Turtle Pro Video
    Training | Editing | Support
    Out Now – Film Wash Color Effects Vol. 3
    for After Effects & Apple Color
