Activity › Forums › Adobe After Effects › Expression:Delete all …
  • Expression:Delete all …
    Posted by Julian Sixx on August 20, 2006 at 3:20 pm
    Hi
    How can i delete all expressions at once of all layers wihin a comp?Not manually!
    Maybe via script Dan,yikesmikes,Colin…?I haven’t found a script yet.
    Thx
    Julian Sixx replied 20 years, 1 month ago 3 Members · 6 Replies
  • Roland R. kahlenberg
    August 20, 2006 at 8:18 pm
    This is a job for scripting and not Expressions. You may want to do a Google for “After Effects” and scripts. It doesn’t sound like something too tricky but I’ve not ventured into scripting – so … .
    Good Luck!
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files”
  • Julian Sixx
    August 21, 2006 at 4:22 am
    hi
    I did a search before posting but i haven’t found one yet (redefinery.com,cr green.com,adobeforum.com,aenhancers etc.)
    I thought it would be a piece of cake for a lot of people here to write this one.
    Thanks anyway 🙂
  • Mike Clasby
    August 21, 2006 at 7:54 am
    This might work, I don’t have AE 7 (yet) so can’t test it.
    rd: Expression Tweaker
    https://www.redefinery.com/ae/view.php?item=rd_ExprTweaker
  • Julian Sixx
    August 21, 2006 at 6:11 pm
    Hi yikesmikes
    thx for your reply
    I’ve already tried this script before,it works only with disabled expressions!You can either remove them or enable them!
    kind regards julian
  • Mike Clasby
    August 21, 2006 at 7:20 pm
    This works on AE 6.5
    1) Select all layers
    2) “ee” to expose expressions only
    3) select all the expressions, by pulling a rectangle selection down, starting just under the layer “twirly” (to the left of the stopwatch)
    then pulling that rectangular selection all the way down from the top layer to the bottom layer.
    4) Animation > Remove expression (Alt + Shift + =)
    The only tricky part is drawing the rectangular selection (with the standard Selection Tool (V)) you have to be to the left of the layer name (left of the stopwatch), if you try it to the right you only select that expression.
  • Julian Sixx
    August 22, 2006 at 3:46 am
    Hi
    thank you very much,it also works perfectly for AE 7!!!!!
