Activity Forums Adobe After Effects Expressions Expression “works” but not as intended.
  • Expression “works” but not as intended.
    Posted by Justin Maloney on May 25, 2016 at 3:57 pm
    So I’m working on a rig for work and I’d like a layer to only appear (via opacity) when certain conditions are met and not appear when other conditions are met.
    Basically, if a layer moves past a certain point, it turns on. If a certain switch is checked, it turns on, and if another different switch is checked, it turns off.
    I’ve done similar things with other layers and it works just fine, but I think here I have too many conditions and AE is getting confused.
    Any suggestions? Thanks =D
    x = thisComp.layer("OPTIONS").effect("Skelotor Mode")("Checkbox");
    b = thisComp.layer("Body Turn").transform.xPosition;
    f = thisComp.layer("C_L hand").effect("Force in Back L")("Checkbox");
    v = value;
    if (b < -10) v =100;
    else if (x == 0) v = 100;
    else if (f ==1) v = 100;
    else v = 0;
    Justin Maloney replied 10 years, 4 months ago 2 Members · 7 Replies
  • 7 Replies
  • Justin Maloney
    May 25, 2016 at 4:10 pm
    Sorry, basically the problem is that the opacity for the layer remains fixed at 100, or if I reverse the values and end with “else if v = 100” it remains fixed at 0.
    Also the first if is supposed to be “if (b < -10) v = 100;”
  • Justin Maloney
    May 25, 2016 at 4:20 pm
    Figured it out. Removed the multiple “else if’s” and moved the position conditional to the bottom. It looks like this…
    x = thisComp.layer(“OPTIONS”).effect(“Skelotor Mode”)(“Checkbox”);
    b = thisComp.layer(“Body Turn”).transform.xPosition;
    f = thisComp.layer(“C_L hand”).effect(“Force in Back L”)(“Checkbox”);
    v = value;
    if (f ==1) v = 100;
    else v = 0;
    Better question: I’ve tried arrays before, but I can’t wrap my head around all the time. Would an array be better for expressions like this one?
  • Justin Maloney
    May 25, 2016 at 4:21 pm
    Nope! Nevermind, doesn’t work. God damn, sorry for premature replies…
  • Dan Ebberts
    May 25, 2016 at 4:35 pm
    You could restructure it like this:
    if ((b < -10) || (x == 0) || (f ==1))
    v =100
    else
    v = 0;
    But you might need to revise it based on the priority of your controls. For example, what should happen if both checkboxes are on?
    Dan
  • Justin Maloney
    May 25, 2016 at 4:49 pm
    Skelotor Mode just brings in a wire frame model and turns off all the assets. I really need to keep this in so the other animators can work with this character rig at a steady pace.
    Any condition where “x” == 1 should set opacity to o%
    This expression is working better then what I had. Thanks man. I’ll keep tinkering!
  • Dan Ebberts
    May 25, 2016 at 4:54 pm
    This might be closer then:
    if (x == 1)
    v = 0
    else if ((b < -10) || (f ==1))
    v =100
    else
    v = 0;
    Dan
  • Justin Maloney
    May 25, 2016 at 5:12 pm
    Dan, you are a god among animators. That worked perfectly.
    Many thanks!
