Activity Forums Adobe After Effects Expressions expression to take value from another comp
  • expression to take value from another comp
    Posted by Graham Quince on May 19, 2005 at 1:55 pm
    Hi guys
    I’m building a virtual room which contains a hinged door and would like to be able to open and close the door with relative ease. I’ve built the door and frame as a separate comp which i’ve nested into the main comp and used the collapse transformations option.
    Everything is fine and using the comp synchronise option, i can jump back and forth from the main comp to the door comp to adjust rotation keyframes, to allow the door to move. but i’m lazy-ish and also curious. 🙂
    is it possible to add a null object to the main comp and have it’s rotation open the door?
    The only expressions i use myself are built with the pickwhip, so i’ve no idea how to go about this.
    Graham
    Mylenium replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mylenium
    May 19, 2005 at 3:14 pm
    Add your null and pick-whip across compositions (dragging on the timeline tabs will open a separate timeline window for a composition) – it’s as simple as that. No fancies required.
    Mylenium
    [Pour Myl
