Activity › Forums › Adobe After Effects Expressions › Expression to rename layers during render
  • Expression to rename layers during render
    Posted by Mike Throck on December 3, 2008 at 8:55 pm
    I’m using AE to convert HD files to SD, pretty simple. Problem is I sometimes have up to dozens of files and it is tedious to rename them all in the render que. Is there an expression that can drive the naming of these files , or a better way all together to do this process?
    Dan Ebberts replied 17 years, 10 months ago 2 Members · 1 Reply
  • Dan Ebberts
    December 3, 2008 at 10:41 pm
    You can’t do it with an expression. You could do it with a fairly simple script, but it would depend on your naming convention.
    Dan
