Activity Forums Adobe After Effects Expression to pick one of six values based on slider
  • Expression to pick one of six values based on slider
    Posted by James Archibald on November 11, 2014 at 11:34 am
    Hey everyone, this feels like it should be a simple one, and it’s definitely something I’ve achieved before but I’ve sort of tangled myself up and can’t quite see where to go.
    I have a slider that is outputting a value between 1 and 6 based on a wiggle:
    w = wiggle(6,4);
    Math.max(1,Math.min(6,w)).toFixed(0)
    I have 6 nulls in 3D space.
    I then have my effect which I want to wiggle between these nulls based on the slider’s “dice roll”. So far I have defined my variables, but I can’t think how to format the expression in order to achieve this.
    This is how far I’ve gotten:
    dice = effect(“Zap Roll”)(“Slider”);
    t1 = thisComp.layer(“Edge Zap Target 1”).transform.position;
    t2 = thisComp.layer(“Edge Zap Target 2”).transform.position;
    t3 = thisComp.layer(“Edge Zap Target 3”).transform.position;
    t4 = thisComp.layer(“Edge Zap Target 4”).transform.position;
    t5 = thisComp.layer(“Pylon 1 – Top”).transform.position;
    t6 = thisComp.layer(“Pylon 1 – Bot”).transform.position;
    if (dice=1) t1
    So if dice=2, the effect value should be t2, etc.
    Any help would be greatly appreciated.
    • Archie •
    James Archibald replied 11 years, 10 months ago 51,579 Members · 1 Reply
  • James Archibald
    November 11, 2014 at 11:48 am
    Derp, sorted it. Knew it was simple, sorry, folks.
    dice = effect(“Zap Target”)(“Slider”);
    if (dice==1) t1
    else if (dice==2) t2
    else if (dice==3) t3
    else if (dice==4) t4
    else if (dice==5) t5
    else if (dice==6) t6
    • Archie •
