Activity Forums Adobe After Effects Expressions Expression to move forwards one frame triggered by thisComp.marker object
  • Expression to move forwards one frame triggered by thisComp.marker object
    Posted by James Baron on January 23, 2019 at 1:41 am
    Hi there,
    Im trying to figure out how to apply an expression to a time remap which will advance one frame every time there is a marker in the main comp
    Thanks in advance!
    James Baron replied 7 years, 8 months ago 3 Members · 6 Replies
  • Brian Holzknecht
    January 23, 2019 at 2:32 am
    Here is something I modified from a previous post I found and it seems to do the trick. Not sure if it’s correct, but it appeared to work for me.
    Brian
    skip = framesToTime(1); // frame skip
    m = thisComp.marker;
    begin = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    begin = n*skip;
    value + begin
  • James Baron
    January 23, 2019 at 2:50 am
    Thanks for your reply Brian! Im getting an expression error running it on time remap though?
  • Brian Holzknecht
    January 23, 2019 at 3:06 am
    Hmm… that’s weird. What version of after effects are you using? I’m using 2018 and In my test I made a 2nd comp that I’m using as a source with the time remap on.
    I’m not really an expression guy, but i figured I’d try to help while I’m waiting for some assistance on my question. Lol.
    I’m not at my computer or I’d try to troubleshoot it right now. Sorry.
    Brian
  • Dan Ebberts
    January 23, 2019 at 4:13 am
    Something like this should work:
    m = comp("Main Comp").marker;
    n = 0;
    if (m.numKeys > 0){
    if (m.key(n).time > time) n--;
    framesToTime(n);
    Dan
  • Brian Holzknecht
    January 23, 2019 at 4:34 am
    Your expression skills are so impressive, the help I tried to provide came from one of your posts to someone else… Clearly I need to learn a ton more on expressions.
    Brian
  • James Baron
    January 23, 2019 at 10:49 pm
    Perfect Dan!! Thanks a lot for your help Dan and Brian
