Activity Forums Adobe After Effects Expressions Expression to make keyframe velocity drive blur amount
  • Expression to make keyframe velocity drive blur amount
    Posted by Bill Porter on August 15, 2013 at 3:54 pm
    Hi folks,
    I’m in a bit of a fix with a very specific problem. I think there would be a solution to it but can’t figure it out or find a previous example.
    I have a fruit machine made in 2d layers and the spins are animated with the motion tile effect. The spins are moving so quickly that the default motion blur looks steppy even with the sample amount turned up to the maximum.
    RSMB doesn’t seem to work as the motion is too fast and it goes a bit weird.
    Rather than keyframe a blur effect manually, I was wondering if there would be a way to link the motion tile ‘Tile Center’ velocity to a blur effect. Then have the blur set to vertical only.
    Does anybody know how I might do this?
    Many thanks,
    Bill
    Bill Porter replied 13 years ago 2 Members · 2 Replies
  • Dan Ebberts
    August 15, 2013 at 4:56 pm
    Play around with this for you blur amount:
    amt = .01;
    effect(“Motion Tile”)(“Tile Center”).speed*amt
    Adjust amt to suit.
    Dan
  • Bill Porter
    August 15, 2013 at 6:31 pm
    Jackpot! Works perfectly, and so elegant.
    Thank you Dan!!!
