Activity › Forums › Adobe After Effects Expressions › Expression to loop but trim last couple of frames?
  • Expression to loop but trim last couple of frames?
    Posted by Xavier Paredes on October 25, 2018 at 4:03 pm
    I have about 200+ videos. Each needs to be looped X amount of times. I have an expression (see below) that allows me to do this and it works just fine for [most] videos. Unfortunately, some videos have a couple of frames of black at the tail end so when I loop them using the expression, those black frames get included therefore they flash every time the loop happens.
    The only way I know to prevent this is to trim the black from the videos in FCPX and re-export them.
    I’m wondering if there’s a better expression so I don’t have to trim and re-export in FCP.
    I’m on a tight deadline :/
    Thanks for any help!
    nLoops = 100;
    if (numKeys > 1){
    loopDur = key(numKeys).time - key(1).time;
    n = Math.floor((time - key(1).time)/loopDur);
    if (n < nLoops){
    t = (time - key(1).time)%loopDur;
    valueAtTime(key(1).time + t);
    }else{
    valueAtTime(key(numKeys).time);
    }else
    value;
    Xavier
    Xavier Paredes replied 7 years, 11 months ago 2 Members · 4 Replies
  • Dan Ebberts
    October 25, 2018 at 4:18 pm
    This is a time remapping expression, yes? One thing you could do would be to move the Current Time Indicator to the last good frame, and set a keyframe there, and then delete the last keyframe. Give that a try.
    Dan
  • Xavier Paredes
    October 25, 2018 at 5:55 pm
    Hi Dan,
    Your solution works! Interesting though, It’s basically the same thing I was doing. The only difference is that I have to move the keyframe [before] I extend the layer. If I extend the layer first and then I move the keyframe, the black frames will show. I don’t understand why but Oh well! ¯\_(ツ)_/¯.
    Thanks!.
    Xavier
  • Dan Ebberts
    October 25, 2018 at 5:58 pm
    You’re not actually moving the keyframe, right? You should be creating a new one a couple frames earlier than the last one then deleting the last one.
    Dan
  • Xavier Paredes
    October 26, 2018 at 2:59 pm
    Uhhhh… I actually was just moving the last keyframe and it works (so long as I do this first before I extend the layer)…
    But I also tried (as you suggested) creating a new keyframe on the last good picture frame of the videos and this works as well.
    I’m going to stick to your most recent advice.
    Thanks so much!
    Xavier
