Activity Forums Adobe After Effects Expressions Expression to Link RGB Fill to layer #
  • Expression to Link RGB Fill to layer #
    Posted by James Curran on October 9, 2008 at 4:19 pm
    I want to render off an image sequence with an alpha channel of an animated reveal (eg. a simple wipe across the screen, from completely transparent to fully opaque).
    I then want to import this sequence into a new comp, with each image in the sequence layered over each other.
    Then, I want to apply a fill effect to each layer and link the rgb value to the layer number in the comp. i.e. layer #1 will be rgb 1 1 1, layer #255 will be rgb 255 255 255 etc…
    Is there an expression that will allow me to do this easily?
    Dan Ebberts replied 17 years, 10 months ago 3 Members · 2 Replies
  • Eric Sanderson
    October 9, 2008 at 5:53 pm
    seems like you wouldnt need 255 layers and expressions to do this, why cant you just animate a change to color from black to white over 255 frames?
  • Dan Ebberts
    October 9, 2008 at 7:35 pm
    Like this:
    myVal = index/255;
    [myVal,myVal,myVal,1]
    Dan
