Expression to drive a Tachometer & Speedometer together
Hi everyone,
I am working on animating a gauge cluster in a car and am trying to get an expression to control the needles in both the speedometer and the tachometer.
I can control the rotation of both individually on sliders, but how would I create an expression to drive both off the animation of the tachometer alone?
Obviously, the tachometer should move significantly more than the speedometer, and the speed should rise but shouldn’t fall when the tachometer needle drops while shifting between gears.
For example, these gauges: https://www.youtube.com/watch?v=q904OkyzrGk
