Activity Forums Adobe After Effects Expressions Expression that checks if Effect on another layer is present
  • Expression that checks if Effect on another layer is present
    Posted by Daniel Hashimoto on March 6, 2019 at 8:53 pm
    I’m trying to create an effect that sets the position of a lens flare to the location of someone’s pupil if you’ve run the Detailed Face Tracker on a layer below – however, I’d like the expression to check whether the Face Tracker effect exists first, and if not, give a different default result.
    So I think I need an if/else to check whether that layer has the effect?
    I was thinking something like this where the this expression is on the location of a lens flare on a Black Solid, above a layer “SOURCE”. Desired output is the Right Pupil location (which works on its own) if the Source layer has the “detailed Face Tracker” effect applied – but will return [0,0] if no effect is present.
    Thank you for your help!
    if(thisComp.layer("SOURCE").effect("Face Track Points")("Right Pupil"))==null){[0,0]}else{thisComp.layer("SOURCE").effect("Face Track Points")("Right Pupil")}
    – Daniel Hashimoto
    \”Action Movie Dad\”
    Daniel Hashimoto replied 7 years, 5 months ago 2 Members · 2 Replies
  • Oleg Pirogov
    March 7, 2019 at 12:28 am
    Since a reference to non-existent property raises an exception, you can use try-catch:
    var someVar;
    try{
    someVar =thisComp.layer("SOURCE").effect("Face Track Points")("Right Pupil");
    catch(err){
    someVar=[0,0];
  • Daniel Hashimoto
    March 7, 2019 at 2:10 pm
    Thank you so much! That’s it!
    – Daniel Hashimoto
