Activity Forums Adobe After Effects Expressions Expression = Slow Render Time?
  • Expression = Slow Render Time?
    Posted by Fred Lobo on October 27, 2008 at 7:45 pm
    Hi folks,
    I’m not a heavy expressions writer, but, with the help of Mr. Dan Ebberts, I was able to wrote a pretty nice code which one big text layer drove a bunch of other small text layers and the opacity of some jpegs layers. The goal was to make an animated wheater forecast that could be updated everyday in a fast and easy way.
    The code did work, but the render becomes extremely slow. I figured it is because it re-reads the expression in every single frame. So, the question is: is there a way to fasten things up? I mean, making the expression read the code just once (in the first frame) and stick with it (without re-checking it every frame to make sure nothing has changed)?
    Thanks in advance,
    Fred Lobo
    Fred Lobo replied 17 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 27, 2008 at 8:26 pm
    A few ideas:
    Animation > Keyframe Assistants > Convert Expression to Keyframes;
    Or, do it with a script;
    Or, possibly make the expression more efficient.
    Dan
  • Fred Lobo
    October 29, 2008 at 4:39 pm
    Hmmm… the “Convert Expressions to Keyframes” thing didn’t work (mostly because I have one Parent layer and a bunch of Child layers, so, to select each one of those and convert it to expressions would be a much harder and time consuming process).
    The problem about scrip is because I don’t know a thing about then -only how to install 🙂
    but thanks anyway Dan,
    fred lobo
