Activity Forums Adobe After Effects Expressions Expression Selector, not a number
  • Expression Selector, not a number
    Posted by Chris Scalzo on August 18, 2020 at 8:27 pm
    I am trying to figure out an easy way to change formatting of all the non numbers
    eg. if I types “1.21 GIGAWATTS”, I would want to change size position and color with text animator to the gigawatts
    with text expression selector and checking if a number to apply value
    Thanks in advance.
    Chris Scalzo replied 6 years ago 2 Members · 2 Replies
  • Filip Vandueren
    August 18, 2020 at 8:49 pm
    This expression for your expression-selector:
    txt=text.sourceText.value.replace(/\r|\n|\u0003/g,"");
    // strips all linebreaks from the string, text Animators don't count those
    if ( txt[textIndex-1].match(/[0-9\.]/) == null) {
    value;
    } else {
    0;
    (I’ve also included the period)
  • Chris Scalzo
    August 18, 2020 at 9:43 pm
    Works perfectly. I was hoping to do without regex since I don’t always wrap my head around it. I appreciate the comment as well in there. Thank you very much.
