Activity Forums Adobe After Effects Expressions Expression Selector Amount 100 for lines of text including : sign
  • Expression Selector Amount 100 for lines of text including : sign
    Posted by Niels b Nielsen on October 17, 2017 at 11:35 pm
    Im trying to “dynamic text” a credit list for Premiere. I want every line with a : sign at the end to be highlighted through an expression for the Expression Selector. Every line with : should have a value of 100, the rest 0. Is this possible?
    Niels b Nielsen replied 8 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 18, 2017 at 12:50 am
    If you have the Expression Selector Based On set to ‘Lines’, this should work:
    txt = text.sourceText.split("\r");
    str = txt[textIndex-1];
    if (str[str.length-1] == ":") 100 else 0
    Dan
  • Niels b Nielsen
    October 18, 2017 at 8:15 am
    Works well. Thanks for your quick help Dan!
