Activity › Forums › Adobe After Effects Expressions › Expression Randomly Disables
  • Expression Randomly Disables
    Posted by Aaron Benitez on May 3, 2013 at 12:00 am
    I’m using a sampleImage expression. When I reference the R,G, or B ([0],[1], or [2]) the expression works but when I reference the alpha( [3]) it will work at first but then disable after a few seconds.
    target =thisLayer;
    a = thisComp.layer("Controller").effect("Sample Area")("Slider");
    alpha = target.sampleImage(effect("Lens Flare")("Flare Center"),[a, a])[3];
    linear(alpha, 0, 1, 0, 100)
    Dan Ebberts replied 13 years, 5 months ago 2 Members · 1 Reply
  • Dan Ebberts
    May 3, 2013 at 12:29 am
    Does it generate an error message? Which version of AE are you using? Which property is the expression applied to?
    Dan
