Activity › Forums › Adobe After Effects Expressions › Expression – random numbers with decimal point
  • Expression – random numbers with decimal point
    Posted by Robert Cornfoot on March 7, 2014 at 9:18 am
    Hello
    Firstly can I say I am new to expressions. However I would like to know if there is a simple way of generating a random number with two further numbers after the decimal point.
    e.g. 15.17
    I have used the ‘Character Offset’ with a wiggle command – wiggle(1,5) but this only produces a two digit number with no decimal.
    Does anyone know a work around?
    Rob
    Amy Young replied 8 years, 7 months ago 3 Members · 5 Replies
  • Dan Ebberts
    March 7, 2014 at 4:10 pm
    I’m not sure if this is exactly what you had in mind, but give this source text expression a try:
    random(100).toFixed(2)
    Dan
  • Robert Cornfoot
    March 8, 2014 at 4:14 pm
    That’s fantastic thanks – just what I wanted.
    One further question. Can the speed of the random numbers be controlled? (slowed down) For example, can the time between each change of digits be extended – so the each digit is on screen for longer.
    Rob
  • Dan Ebberts
    March 8, 2014 at 4:38 pm
    Something like this probably:
    frames = 5; // frames to hold each random number
    seed = Math.floor((time – inPoint)/framesToTime(frames));
    seedRandom(seed,true);
    Dan
  • Robert Cornfoot
    March 9, 2014 at 2:35 pm
    Thanks a million Dan. Perfect!
    Rob
  • Amy Young
    February 10, 2018 at 3:00 am
    Still very useful — thanks Dan!
