Activity Forums Adobe After Effects Expression Question
  • Expression Question
    Posted by Bob Archer on May 23, 2007 at 4:13 pm
    I’m animating a sunrise, and I’m using an expression on a four color gradient to connect the position of one of the gradients (the bright color to serve as a glow) to the center of the sun.
    Currently the sun is coming from the lower left of frame and arching into the lower right. The issue I am having is the sun I made is fairly large and in order to benefit from the gradient point’s spread, I would like to make the expression so it’s referencing the center of the sun, but adding a few points up from the center of the sun.
    I was thinking of using vector math to add to the x and y in the expression, but I can’t figure it out to where it’s written correctly.
    Here’s what I have right now: thisComp.layer(“sun.ai”).transform.position
    Hopefully this explanation makes sense and thanks in advance for your help.
    Bob Archer replied 19 years, 4 months ago 2 Members · 2 Replies
  • Darby Edelen
    May 23, 2007 at 4:17 pm
    You can just add a vector to the position of the sun:
    thisComp.layer("sun.ai").transform.position + [0,10]
    This will add 0 pixels to the x value and 10 pixels to the y value. If your sun is a 3D layer (which it probably isn’t or you’d have even more issues using a 2D effect to reference it) you will need to add [0, 10, 0] to the position.
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Bob Archer
    May 23, 2007 at 4:30 pm
    Thanks for the quick response. I knew it was going to be something easy. I forgot all about just adding to the position points. When it comes to expressions, I tend to overthink things a bit.
