  • Posted by Alek Panfilov on October 18, 2005 at 10:56 am
    once again i have a Q about expressions,
    firt of all, in comp i have a slider wich is generating random numbers between 0 and 100 ,
    and also i have 8 solids, attached to objects in zaxwerks inv, and i want Z-3d-scale values of
    those solids to act like equalizer led, so i was thinking about expression for the Z-3d-scale value
    of those solids wich will look something like this :
    temp = thisComp.layer(“slider”).effect(“Slider Control”)(“Slider”);
    temp2 = if(temp //HERE I DONT KNOW WHAT TO ENTER// = array (20, 100))100 else 0
    [100, 100, temp2]
    and now explanation to my heretical writings 😛
    i whant temp2 to be 100 when temp is in array between 20 and 100, when its below 20, temp2 is 0.
    i’m little lost in expression , so maybe it’s not properly wrighted, but way of thinking is good 😉
    cheers.
    Alek Panfilov replied 20 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 18, 2005 at 1:20 pm
    I think you just need something like this for the middle line of your expression:
    if (temp < 20) temp2 = 0 else temp2 = 100; Dan
  • Alek Panfilov
    October 18, 2005 at 1:26 pm
    thankyou Dan 🙂
