Activity › Forums › Adobe After Effects › expression problem
  • expression problem
    Posted by Stephen Hockman on November 9, 2005 at 9:36 pm
    i alt clicked the size keyframe button and i typed in random(100,120) to randomize my size. When i hit enter i get the following error: After effects warning: expression result must be of dimension 2, not 1, error occured at line 0, expression disabled.
    whats up? how i fix it>
    Colin Braley replied 20 years, 10 months ago 2 Members · 1 Reply
  • Colin Braley
    November 9, 2005 at 11:02 pm
    Well scale is a two dimensional property, meaning the first number is X scale and then Y scale. When you type random(100, 120) you are only specifying the X scale so after effects is telling you it needs a number for Y scale too. You might want to try one of hese expressions:
    val = random(100, 120);
    [val, val]
    //or
    [random(100, 120), random(100,120)]
    for this kind of basic expression stuff you can usually find the answer on Dan Ebberts’ site http://www.motionscript.com
    ~Colin
