Activity › Forums › Adobe After Effects › Expression : Position offset from layer above – HELP
  • Expression : Position offset from layer above – HELP
    Posted by Andy Stokes on May 10, 2005 at 5:35 pm
    Hi all,
    Is there an easy way to take the position of a layer from the layer above it but with an additional position offset ? For example the layer beneath is 10px down and 10px left of the layer above it. I hope this is clear.
    I was thinking something like below although I can’t seem to input the individual x,y,z offsets ??
    “thisComp.layer(this_layer,-1).position” ??????
    Any suggestions would be greatly appreciated. If it could also tied in with a slider control to adjust the amount of offset, that would be even better.
    Cheers,
    Andy
    Mike Clasby replied 21 years, 4 months ago 3 Members · 3 Replies
  • W M d
    May 10, 2005 at 6:18 pm
    How about this….
    thisComp.layer(index-1).position + [-10,10]
  • Andy Stokes
    May 11, 2005 at 4:47 am
    Hi Gaterwink,
    Thanks.. I wasn’t sure how to put the offset values into the string. After a little experimenting with your orignal string I’ve figured out how to include a slider to control the offset. In case anyone else is interested, here it is :-
    X = thisComp.layer(“OFFSET”).effect(“slideX”)(“Slider”)*1;
    Y = thisComp.layer(“OFFSET”).effect(“slideY”)(“Slider”)*1;
    thisComp.layer(index-1).position + [X,Y]
    Thanks again,
    Andy
  • Mike Clasby
    May 12, 2005 at 12:45 am
    Thanks for sharing.
