Activity › Forums › Adobe After Effects Expressions › expression needed…please
  • expression needed…please
    Posted by Brian Mcgovern on April 13, 2007 at 3:37 pm
    an easy one I’m sure, but I am animating an arrow along a path. How do I make sure the point of the arrow follows the path as it animates. I can manually control the arrow’s rotation as it animates along the path, but it still doesn’t look right.
    I want to make sure the point of the arrow is always front and center as it animates.
    Thanks in advance.
    Brian
    Filip Vandueren replied 19 years, 5 months ago 2 Members · 1 Reply
  • Filip Vandueren
    April 13, 2007 at 4:31 pm
    No expression needed, look up “auto orient” in the manual.
    The setting “orient along path” will (in most cases) do what you need.
    If you do have a problem with certain motions, it can be solved with expressions, check back.
