Activity › Forums › Adobe After Effects Expressions › Expression illiterate. Please help me with this basic expression:
  • Expression illiterate. Please help me with this basic expression:
    Posted by Jeremy Garchow on May 3, 2007 at 8:06 pm
    I am key framing two layers of text for position, I need the bottom text layer to be the exact same position as the one on top, except the the x value needs a value of 4 added to it (to move the bottom layer 4 pixels to the right of the top layer).
    Does this make sense? I can’t figure out the expression language and key framing them all is cool but annoying, and this seems like a perfect time to learn a simple expression to train my expression feeble mind. Thanks a lot in advance.
    Jeremy
    Jeremy Garchow replied 19 years, 5 months ago 3 Members · 5 Replies
  • Lord Scales
    May 3, 2007 at 9:11 pm
    x = thisComp.layer(“name”).transform.position[0]+4;
    y = thisComp.layer(“name”).transform.position[1];
    [x, y]
    Lord Scales
  • Jeremy Garchow
    May 3, 2007 at 9:51 pm
    You are and king/queen among men/women.
    I take that back, you are a lord of scales.
    Jeremy
  • Filip Vandueren
    May 4, 2007 at 1:19 am
    In Motionscript, you can add two vectors simply together like this:
    [10,10] + [2,4] => [12,14]
    since the position contains a vector, the expression can be as simple as:
    thisComp.layer(“name”).transform.position + [4,0];
    (this used to not always be the case – 5.5 ? -there was a function called Add or vectorAdd, or something like that)
  • Lord Scales
    May 4, 2007 at 1:30 am
    Nice info, Filip! I guess this function was addVector(?).
    I really like the variables. Even this being a simple expression, I have to simplificate it. Since I started to study Dan Ebberts’ Motion Script.com, I started creating variables to everything.
    They are really useful and the best is that we can add a lot of names to them and it is easy to memorize.
    Lord Scales
  • Jeremy Garchow
    May 4, 2007 at 3:09 am
    If the text layer is 3D, it’s as simple as adding a z vector, no?
    thisComp.layer(“name”).transform.position + [4,0,0];
    Thanks again. Extremely helpful.
    Jeremy
