Activity › Forums › Adobe After Effects Expressions › expression help: writing to text file
  • expression help: writing to text file
    Posted by Jason Rayles on July 12, 2006 at 6:24 pm
    Can I use scripting in after effects to write to a text file? I want to write out keyframe values for a particular property to a comma-delimited text file. If that’s not possible, is there a way to display all the values in some kind of debugger so I can copy the values from ae and paste them into a text file?
    Jason
    Dan Ebberts
    replied 20 years, 2 months ago
    3 Members · 2 Replies
  • Mylenium
    July 12, 2006 at 7:59 pm
    Sure you can write files to disc using scripts. Check AEnhancers.com for some inspiration.
    Mylenium
    [Pour Myl
  • Dan Ebberts
    July 12, 2006 at 9:20 pm
    Have you tried selecting all the keyframes, copy, then paste to text editor (or excel)? You get some header stuff, but you also get all the tab-delimited values. Check it out.
    Dan
