Activity Forums Adobe After Effects Expression help – movement by object proximity
  • Expression help – movement by object proximity
    Posted by Daniel Poffley on April 12, 2021 at 10:13 am
    Hi all. Can anyone help me with this one?
    Imagine a comp with two circles.
    Circle A is moving around randomly.
    Circle B is static.
    When circle A moves near to circle B (lets say within 200 pixels), I would like circle B to move away in the opposite direction, then return to its start position when circle A is over 200 pixels away.
    I’ve found several scripts, but they always seem move the circle in a specific X/Y direction rather than away from the other object.
    Does something like this exist?
    Thanks.
    Tim Wilson replied 5 years, 5 months ago 3 Members · 4 Replies
  • Ben King
    April 12, 2021 at 10:20 am
    The Newton 2D physics engine for AE might be worth looking at… https://www.motionboutique.com/newton-physics-simulator-engine-after-effects/
  • Daniel Poffley
    April 12, 2021 at 10:28 am
    Thanks Ben. I’ve not heard of this plugin before. I’ll take a look.
    I am wondering if there is a way of doing this without plugins.
  • Daniel Poffley
    April 12, 2021 at 11:58 am
    Found it.
    You can set an expression so square B always faces square A, then modify its anchor point, which will push it away in the opposite direction.
  • Tim Wilson
    April 13, 2021 at 5:48 am
    Wow, very elegant indeed! Thanks Daniel!
