Activity › Forums › Adobe After Effects Expressions › Expression Help for Learner
  • Expression Help for Learner
    Posted by Christopher Rotter on June 13, 2009 at 5:21 pm
    temp = transform.position[1];
    [temp, temp;]thisComp.layer(“Particle layer”).effect(“Particular”)(“Size”)
    I’m trying to have a null, y position control the size of the particles but AE gives me an error, I’m
    thinking it’s because I have to fill in the array {temp, temp} ? Also what would I need to add to that
    expression, so when the particles fade off, the colors from a colorama effect on another layer change
    color, but I can easily change the color to whatever I want ? I’m in the mist of learning expression
    in AE as well, quite interesting 🙂
    Christopher Rotter replied 17 years, 3 months ago 2 Members · 6 Replies
  • Dan Ebberts
    June 13, 2009 at 5:35 pm
    To control the particle size by the y coordiante of a null, you would need to apply an expression like this to the particle size property:
    thisComp.layer(“Null 1”).transform.position[1]
    Dan
  • Christopher Rotter
    June 13, 2009 at 11:10 pm
    TrapCode Particular doesn’t allow expressions on it’s settings
  • Dan Ebberts
    June 14, 2009 at 2:21 am
    I’m having a hard time figuring out how you came to that conclusion. I just tried it and it works fine for me.
    Dan
    June 14, 2009 at 5:33 pm
    There is no stop watch on the Aux -> Particle Size within Trap code and it doesn’t allow me to add an expression ?
  • Dan Ebberts
    June 14, 2009 at 6:28 pm
    Ah, I thought you were trying to animate the Particle Size property rather than Aux Particle Size. Sorry, there’s no way for an expression to control a property that doesn’t have a stopwatch.
    Dan
    June 14, 2009 at 8:13 pm
    I’ll just have to keyframe the size.
