Activity › Forums › Adobe After Effects Expressions › Expression for start time and duration
  • Expression for start time and duration
    Posted by Erik Fashingbauer on September 11, 2020 at 12:04 am
    I’m building a motion graphics template for a client that is a simple text typewriter effect.
    Basically for any given line of text I need an expression on the range selector that I can link to a slider control for duration of text typing on from 0-100 and a slider for start time so I can control when the typing animation begins.
    This expression time*100 works by itself to control the duration. I can link the value to a slider ultimately and it works fine.
    I used the following expression to determine start time.
     timeToStart = 2;
      if (time > timeToStart){
          wiggle(3,25);
      }else{
          value;
    this works and the animation starts at 2 seconds. The problem is this expression wiggles the value which is not what I need so I replaced “wiggle(2,25)” with “time*100” but it doesn’t seem to work. I think because the word time is already defining start time, it can’t also be used to define duration maybe?
    Does anyone know how I can make this work??
    Erik Fashingbauer replied 6 years ago 2 Members · 2 Replies
  • Andrei Popa
    September 11, 2020 at 12:03 pm
    I think you should use this expression for the “Start” of the typewriter effect. You can link dur and timeToStart to your sliders
    timeToStart = 2;
    dur = 2;
    linear(time,timeToStart, timeToStart+dur,0,100)
  • Erik Fashingbauer
    September 22, 2020 at 8:26 am
    Yes.
    thank you! this worked great!
