Activity › Forums › Adobe After Effects Expressions › expression for showing layer marker text
  • expression for showing layer marker text
    Posted by Aharon Rabinowitz on August 21, 2006 at 12:26 pm
    Hi folks –
    Is there a way to make the layer marker text show up in the comp window. I am assembling 110+ short cartoon shots and I want to be able to watch the video and see what shots need fixing. We have them numbered and marked off on the audio layer, and I can always duplicate the audio layer and swap it out for a solid if that helps, but I want to put the scene numbers up on the screen so that I know exactly what shot number needs fixing.
    Thanks.
    Aharon
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
    Aharon Rabinowitz replied 20 years, 1 month ago 5 Members · 25 Replies
  • 25 Replies
  • Dan Ebberts
    August 21, 2006 at 1:19 pm
    Aharon,
    Apparently it you could do it older versions, but newer versions have a bug that prevents access.
    Dan
  • Aharon Rabinowitz
    August 21, 2006 at 2:00 pm
    well doesn’t that just suck.
    I haven’t updated to the latest AE 7 update yet, have you? maybe it’s fixed?
    Anyway, how would you do it, if it did work? Is it comlicated?
    Thanks anyway!
    Aharon
    Aharon Rabinowitz
  • Dan Ebberts
    August 21, 2006 at 2:33 pm
    No, it’s broken in AE 7. I think it was supposed to be like this, but I haven’t tried it (with AE 5.5 presumably):
    marker.key(index).value
    Dan
  • Paperinik
    August 21, 2006 at 3:48 pm
    Dan, where do I eventually apply this expression? Which solid’s parameter?
    Thanks.
    Paperinik
  • Dan Ebberts
    August 21, 2006 at 4:42 pm
    Well, I’d guess you’d apply it to the source text of a text layer.
    Dan
  • Aharon Rabinowitz
    August 21, 2006 at 4:47 pm
    what if your markers are on a different layer. How would you tell it that?
    Aharon Rabinowitz
  • Paperinik
    August 21, 2006 at 5:00 pm
    But in this case the only expression:
    index
    work fine in source text of AE 7.
    Paperinik
  • Paperinik
    August 21, 2006 at 5:05 pm
    to Aharon
    in that case the expression is:
    thisComp.layer(“Solid N”).index
    where “Solid N” is the name of your targer solid.
    Paperinik
  • Aharon Rabinowitz
    August 21, 2006 at 5:34 pm
    Thanks, but That’s telling me what layer number it is. I’m looking for the expression to tell me what text is on the layer markers.
    Aharon Rabinowitz
  • Dan Ebberts
    August 21, 2006 at 5:39 pm
    It would be like this:
    thisComp.layer(“Other Layer”).marker.key(1).value
    Dan
Page 1 of 3
