Activity › Forums › Adobe After Effects Expressions › expression for showing layer marker text
Aharon Rabinowitz replied 20 years, 1 month ago 5 Members · 25 Replies
Paperinik
August 21, 2006 at 5:45 pmOh, I’m sorry. I’ve confused layer marker with layer number.
Paperinik
Aharon Rabinowitz
August 21, 2006 at 5:52 pmThanks.
What I get is “Oject Marker property” instead of text.
So that’s the problem, right?
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Filip Vandueren
August 21, 2006 at 8:03 pmHi Aharon,
the Markers don’t happen to be called just 1,2,3,4,5,6 etc ?
or “scene 1”, “scene 2″…if so, this hack can help:
l=thisComp.layer(2); // pickwhip your markerlayer.prefix = "scene ";
min=1;
max=110;resultText="";
for (i=min;i<=max;i++) { try { markerText=prefix+i; m=l.marker.key(markerText); if (m.time>time) {
resultText=markerText;
// if you're sure they're numbered correctly (1 2 3), you can enable the break
// break;
} catch(e) {}
}resultText;
Also a script would probably not be affected by the bug, or usefull assistants might have a script.
Aharon Rabinowitz
August 22, 2006 at 12:49 amHi Filip-
Yes – They are simply 1 2 3
Unfortunatley, I couldn’t get this to work. I don’t beleive I’m setting this up correctly or pasting the code in properly.
Can I ask you to post an example of this maybe with a text layer and a solid containing some markers, just to see how it should be arranged.
Thanks for all of your help.
And Dan thank you too. You’re always a huge help.
Aharon
Aharon Rabinowitz
Dan Ebberts
August 22, 2006 at 4:34 amAharon,
If they’re just numbered sequentially, this expression for source text will give the number of the most recent marker:
L = thisComp.layer(“audio layer”);
n = 0;
if (L.marker.numKeys > 0){
n = L.marker.nearestKey(time).index;
if (L.marker.key(n).time > time){
n–;
if (n==0)”” else nDan
Filip Vandueren
August 22, 2006 at 11:01 amLuckily you have people in different timezones working on this 😉
anyway there was an error in there of course (was getting late for me…)
here’s the correct code:
prefix = “scene “;
min=0;
max=110;resultText=””;
for (i=min;i<=max;i++) { try { markerText=prefix+i; m=l.marker.key(markerText); if ((m.time
Mike Clasby
August 22, 2006 at 12:02 pmAfter Effects warning: Expected: ).
Error occured on line 13.
Expression disabled.This line, methinks:
if ((m.time resultText=markerText;
I tried subbing in two lines (below) from your first expression for the one above, these seemed logical (hacker’s logic), it wasn’t broken then, but still no text appears, I did the pickwhip to the layer with the markers and the expression is on the Source Text stopwatch of a Text layer:
if (m.time>time) {
resultText=markerText;I need to upgrade so I can see the aep, me bad.
Filip Vandueren
August 22, 2006 at 5:11 pmShoot,
it’s an html related error, if you look at the source code of the page (or the emails) you’ll see it’s there, it doesn’t show up, that happens with > and <, symbols: html thinks it's a tag so it doesn't show up. anyway here it is again HTML encoded (this will look like gibberish in the auto-reply emails: l=thisComp.layer(2); // pickwhip your markerlayer. prefix = "scene "; min=0; max=110; resultText=""; for (i=min;i<=max;i++) { try { markerText=prefix+i; m=l.marker.key(markerText); if ((m.time<time)) { resultText=markerText; // break; } } catch(e) {} } resultText;
Mike Clasby
August 22, 2006 at 6:16 pmThanks for the comeback. I still can’t get it to work for me, but I’ll just keep a lookout for an Aharon response and if he’s good to go, then I’ll know I’m doing something basic, wrong.
