Activity › Forums › Adobe After Effects › Expression for Random placement of layers in z and x depth but all the same y ?
  • Mike Clasby
    December 11, 2006 at 6:21 am
    Here’s a hack from a Colin expression, on position of a 3D layer:
    minX = -500;//Minimum x depth value
    maxX = 1000;//Maximum x depth value
    minZ = -500;//Minimum z depth value
    maxZ = 2000;//Maximum z depth value
    seedRandom(index, true);
    x = random(minX,maxX);
    z = random(minZ, maxZ);
    [Math.round( x), position[1], Math.round( z )]
    Change the numbers (pixels) to spread or narrow the field, you could set up a slider on a null and easily change the spread. The Z is -500 so it falls in front of the default camera.
    Here’s Colin’s original post, it was for Random Z:
    https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=2&postid=879394
  • Mylenium
    December 11, 2006 at 6:44 am
    Answered this at CGTalk. Please do not cross-post in the future. It’s simply inefficient to take away from two people’s free time when one could do the job just as well. ;O) Thanks.
    Mylenium
    [Pour Myl
  • Mike Clasby
    December 11, 2006 at 6:58 am
    To answer you second question (Mylenium’s other mentioned forum), you can apply expressions on a mass basis by selecting the expression (position here) then Edit>Copy Expression only, then select as many layers (100’s ?) as you want to have the expression, and Paste.
  • Mylenium
    December 11, 2006 at 7:01 am
    Thanks yikes, completely overlooked that. ;O)
    Mylenium
    [Pour Myl
  • Jack Hilkewich
    December 11, 2006 at 6:50 pm
    Thanks for the answer guys!
    As for cross posting, I tend to disagree with you on this one, Mylenium. If I am researching for an answer to a question and I only post to one forum and then wait until I get an answer from that one forum that would not be very efficient. A number of people that use Cgtalk may not utilize Creative Cow and vice versa. This allows me to get the most mileage out of a problem’s solution by getting a larger amount of different people responding. Especially if you are working on a contract with a client waiting for his ad , time is very important.
    I do however try not to double post on the same forum.
    I mean no disrespect with this post.
    Thanks for all your help!
