Activity Forums Adobe After Effects Expressions Expression for evenly spacing the value of a slider, in a series of duplicates
  • Expression for evenly spacing the value of a slider, in a series of duplicates
    Posted by Jon Smith on February 16, 2009 at 4:49 pm
    I’m looking for an expression that would allow me to evenly distribute the value of a slider effect applied to many duplicates.
    i.e. slider on the first layer is 3, the second 6, the third 9, etc…
    Ideally I would like the value between each layer to be easily adjustable without having to manually edit each layer.
    I’ve seen a couple posts that show how to evenly space layers in space, but can’t seem to translate those expressions into what I need.
    Any help is much appreciated.
    Jon Smith replied 17 years, 7 months ago 2 Members · 2 Replies
  • Filip Vandueren
    February 16, 2009 at 5:01 pm
    You can use the index of the layers and multiply that by 3.
    firstLayer = 2; // the index of the first slider-layer
    (1 + index - firstlayer) * 3;
    If you want to change the value of 3, create another slider on a Null, and pickwhip to that, so you get something like:
    (1 + index - firstlayer) * thisComp.layer("Null 1").Effect("Slider Control")("Slider");
  • Jon Smith
    February 16, 2009 at 7:04 pm
    You make it look so easy. Thanks a bunch Flip.
