Activity › Forums › Adobe After Effects › Expression for displaying currently displayed footage name?
Posted by Dominic Tremblay on August 24, 2005 at 6:51 pmSoory for the duplicate post post, I thought I would use a more self-explanatory title..:)
Hi!
Here is what I would like to do, have a comp filled with an edit of a bunch of clips and have atext lyer on top that gives me the name of the currently displayed clip. I’m able to get one footage name to link to the source text but is there a way to tell the expression to look for the currently displayed footage name?
D.
Joel Corkin replied 21 years ago 5 Members · 8 Replies -
Dan Ebberts
August 24, 2005 at 7:20 pmTry this source text expression:
txt = ""; for (j = 1; j <= thisComp.numLayers; j++){ if (j == index) continue; L = thisComp.layer(j); if (! (L.hasVideo && L.active)) continue; if (time >= L.inPoint && time < L.outPoint){ try{ txt = L.source.name; }catch(err1){ txt = L.name } break; } } txtDan
Steve Freebairn
August 25, 2005 at 2:51 pmDan Ebberts has to be the very best expressions person in the world. He responds to everyone and has his own great site that has taught me a ton, you should check it out. http://www.motionscript.com/
Joel Corkin
September 20, 2005 at 6:56 amSorry, I am trying to get this to work, but am having some trouble. Don’t I just need to paste Dan’s code into an expression for the SourceText property of a text layer?
Joel Corkin
September 20, 2005 at 6:07 pmI figured out that this code only works if you have one text layer in your comp. Anyone know how it could work while other text layers are present? Dan?
Joel Corkin
September 20, 2005 at 6:31 pmPerhaps there is some way tell AE to do either of the following in the case of wanting to use additional text layers in your comp:
– Disregard any other layer if it is a text layer
or
– Disregard all layers above the layer to which you are applying this particular sourceText code.Any thoughts?
Joel Corkin
September 20, 2005 at 6:51 pmOkay, first, sorry for so many follow-up posts, but I figured out a way to make this work while disregarding certain other layers, like other text layers that span the whole comp for example.
I added &&!L.hasParent into Dan’s code and then created a null layer with visibility off, which I used as the parent to whatever other text layers I want to add to the comp. This way the other text layers can span the comp without interfering with the footage name display.
The modification of Dan’s code is below. If anyone has a better way than this, please post it.
txt = “”;
for (j = 1; j <= thisComp.numLayers; j++){ if (j == index) continue; L = thisComp.layer(j); if (! (L.hasVideo && L.active &&!L.hasParent)) continue; if (time >= L.inPoint && time < L.outPoint){ try{ txt = L.source.name; }catch(err1){ txt = L.name } break; } } txt;
