Activity Forums Adobe After Effects Expressions Expression for color control
  • Expression for color control
    Posted by Pierre-alexis Tremblay on March 15, 2009 at 2:02 pm
    Hi, I like to use expressions but am not very good at programming.
    I’m trying to figure out a way to randomly assign a color from a custom color palette (few colors, let’s say maximum 12) to a shape layer. Thanks for helping.
    Andy Teel replied 7 years, 2 months ago 15 Members · 25 Replies
  • 25 Replies
  • Filip Vandueren
    March 15, 2009 at 3:38 pm
    For versatility and easy tweaking, we’ll store the colors in a control layer:
    Create a Null object called ‘Colors’
    Add as many “Expression Controls -> Color Controls” to that as you need.
    Add this expression to the color you want to control (probably the fill of your shape layer):
    l=thisComp.layer("Colors");
    // retrieve colors stored in the color controls
    i=1;
    colors=[];
    try {
    while(l.effect(i)) {
    // an effect exists, but is it a color control ?
    // We'll check if it's first parameter is called "Color"
    if (l.effect(i)(1).name=="Color") {
    colors.push(l.effect(i)(1).value); // store the color in a list
    i++;
    } catch (e) {}
    // Now if the list of colors contains any elements
    // we will get a random value from the list.
    if (colors.length) {
    r=Math.floor(random(colors.length)); // a random integer
    colors[r]; // return the color
    } else {
    // the list of colors is empty, so we use the existing color value.
    value;
    This expression will change the color every frame.
    Perhaps not what you need, so let us know what you want to do with the random values.
  • Pierre-alexis Tremblay
    March 15, 2009 at 3:58 pm
    Works fine! Thanks a lot.
  • Gabriel Netto
    March 10, 2010 at 4:44 pm
    I’m an expressions newby so…
    Could someone help me with this question?
    I’m working on a CARD project based on 4 variables (CS3). As you will see they are on an external txt and code is located on a text layer. I’m using “Hoyle Playing Cards” font symbols and that’s why they need to change: s = “q” (s for spades is q character, etc.)
    My problem is that I need to alternate between red and black font colors. (spades and hearts have to be red, spades and clubs have to be black) but I just can’t figure out how to change this colors using expressions… I’ve tried to use fill but I don’t know how to set it’s color property via expressions.
    Maybe a Color Control or a sampleImage() effect?
    Any help is really appreciated!!!
    Thanks in advance!
    Gabriel Netto
    //Here's my code:
    s = "q";
    c = "w";
    d = "e";
    h = "r";
    eval(thisComp.layer("LER_TXT").text.sourceText.value);
    myPath = "/MyHD/Prog1.txt";
    try{
    $.evalFile (myPath);
    eval(thisComp.name)[1];
    }catch (err){
    "not found"
  • James Hawkins
    February 1, 2011 at 10:50 pm
    This is a great technique! But what would one need change in order to have it hold the chosen color for the duration? Rather then change every frame.
  • Dan Ebberts
    February 1, 2011 at 11:30 pm
    Just make this the first line of the expression:
    seedRandom(index,true);
    Dan
  • Jarek Borzecki
    January 29, 2013 at 10:39 pm
    Hi All,
    i’m completelty green with svripting, really appreciate if you can help me as well.
    In main comp i’ve created null object with expression control>color controll, and there are two effects ‘fill’ for example ‘font1’ and ‘font2’
    i want to change color for font1 in this comp – this is working fine for me, but i have problem when i’m trying to controll color for font2 inside another compostition..is it possible or can i only controll colors/effects by expressions inside the same composition?
    thank you for your help
    J
  • Dan Ebberts
    January 29, 2013 at 10:46 pm
    You have an expression for Fill effect Color in the other comp linked to the color control in the main comp, is that correct? That should work just fine.
    Dan
  • Jarek Borzecki
    January 29, 2013 at 11:12 pm
    hi Dan,
    correct,
    !Main_Composition with Colour Control layer (my null object) and Artwork Colour – my fill effect
    and another comp ‘WMan’ with fill effect
    I’m receiving this error:
    Error occured at line1.
    Comp: ‘Wman’
    layer: 2 (w1_ai)
    Property: ‘Color’
    comp("!Main_Composition").layer("Colour Control").effect("Artwork Colour")("Color")
  • Jarek Borzecki
    January 29, 2013 at 11:20 pm
    hi Dan,
    correct,
    Comp: ‘Wman’
    layer: 2 (w1_ai)
    Property: ‘Color’
  • Dan Ebberts
    January 29, 2013 at 11:35 pm
    I just tried it with your comp, layer, and effect names, and it works fine for me. I have no idea what it’s not working for you.
    Dan
Page 1 of 3
